0 members (), 344 guests, and 5 robots.
#38577 05/26/04 11:55 AM
Dave55 Offline OP
I just received a magazine from Fluke and was wondering what kind of testers you use. I'll be honest here and say I'm a little cheap. I went to my truck and I have a GB digital multi-meter, a GB circuit tracker, and a GB pen type non-contact voltage probe. I probably got them all at the local hardware store. I've never bought or used a megger. Aside from the expense, I think I'd be afraid to lay a Fluke down on the jobsite.
What do you use?
Dave
#38578 05/26/04 12:49 PM
Big Fluke fan here.
I keep a model 87 DMM in the truck, along with an 80i-400 clamp-on AC current probe. For more sophisticated testing, I drag out a 123 ScopeMeter. And a Fluke non-contact voltage detector lives right in my toolbelt.
Other gear includes a Supco megger, Harris toner/tracer set, and a homebrew telephone "buttset" (El Cheapo corded phone w/zip cord and red/green alligator clips attached).
My electronics testbench has a Fluke 8060A DMM, along with a Tektronix scope, a couple HP signal generators, and a handful of Heathkits (remember those?).
[This message has been edited by NJwirenut (edited 05-26-2004).]
#38579 05/26/04 02:05 PM
In order from the most used to the least:
Greenlee BEHA Unitest
Etcon polarity / GFI test
Ideal Pathfinder for USOC, CATx & coax (with toner)
Generic VOM ~$12, less if I find one
Non-contact volt sniffer
Amprobe clampon
Generic buttset
Ideal ABS (Almost a Buttset)
Amprobe open finder
Al Hildenbrand
#38580 05/26/04 03:27 PM
I too am a big Fluke fan (investor). I have the Model 87V and the i1010 AC/DC Current Clamp.
For those who fool with network wiring on a regular basis they make a wonderful series of handheld network testers. I bought the MicroScanner Pro and wonder how I ever did without it.
[This message has been edited by Mean Gene (edited 05-26-2004).]
#38581 05/26/04 05:37 PM
I use a combination of Fluke,Robin,Megger,Martiundale and Metrohm test equipment
#38582 05/26/04 09:07 PM
My meters.
Roger
#38583 05/26/04 09:23 PM
twh Offline
1 - cheap clamp meter for most use.
1 - Fluke 87 III with clamp for more accurate readings,
1 - cheap digital megger, because I don't want to be responsible for changing a 100 HP motor unless I'm really sure.
assorted - unreliable volt ticks.
1 - apprentice to check wires after the volt tick
#38584 05/26/04 10:52 PM
CRM Offline
An amprobe ac/dc clamp on multi meter is the best value for the money, I've been using them for ten years with no problems.
#38585 05/26/04 10:56 PM
First of all, this is NOT an ad, and I'm not getting paid in any way...
Secondly, I own an (according to Fluke) an exceptionally accurate Fluke.
That said, I reccomend someone else.
FIeldpiece. They make meters for Ideal. The model that they market to the HVAC market is a 'stick' that easily fits in a pocket. Slip-on heads allow assorted additional uses, such as an amp-clamp, true-rms, temp, etc. Heads can be bought as you need them. Leads have interchangeable tips- need an alligator clip, change the tip. Check out their website.
Available at HVAC suppliers.
#38586 05/26/04 11:49 PM
... I've got...an Amprobe AC/DC3000,an Etcon solenoid Voltage/Continuity Tester,an Ideal "pen-type" inductive tester,a Fluke "pen-type"inductive tester,a Fluke TS1000,ammeter/digital voltmeter,ohm-meter,2 Ideal circuit breaker identifiers,an old analog Heathkit VOM,...and my trusty thumb and fore-finger.. [Linked Image] [Linked Image]
Russ
