0 members (), 220 guests, and 10 robots.
#36048 03/30/04 12:50 AM
[There is a good spoof on Nixie displays at http://www.gpstime.com/nixie.html]
On high-impedance voltmeters and "ghost" readings, NEMA engineering bulletin 88 dated Oct 1998 suggesting a parallel resistor. The concept is valid but their recommended RESISTOR CAN BE DEADLY.
http://www.nema.org/engineering/papers/PhanBull88.html
Their Feb 2003 revision of engineering bulletin 88 quietly axed the resistor suggestion.
http://www.nema.org/docuploads/97F7D189-813B-4EFB-95A878ADAD82F954//bul88.pdf
#36049 03/30/04 04:51 AM
Now how do we get a web page to produce the warmth that tubes gave or the special dusty smell of old tube gear or 60 cycle hum or ...
What exactly is the safety concern over a shunt resistor?
The only two things I can see are the following:
1. There's a remote possibility of the resistor shorting-out, resulting in a near zero-ohm condition between the probes. That objection could be overcome by using fused test leads, as are commonly fitted to industrial meters these days anyway.
2. There will be a much lower resistance between the leads, and thus a greater risk of shock if someone is touching one probe while the other is being connected to a hot terminal. But that's just down to proper procedure: I always make sure the second lead is safe while connecting the first anyway.
#36050 03/30/04 06:05 PM
I have no argument with the concept of a shunt resistor, but someone at NEMA had their head up their hind end when recommending 500-1000 ohms.
From http://www.nema.org/engineering/papers/PhanBull88.html
  • NEMA recommends placing a resistor of approximately 500 to 1000 ohms across high-impedance multimeters.
OK, so 500 ohms across 120V results in a power dissipation of ~29 watts.
And, 1000 ohms across 240V results in power dissipation of ~58 watts.
In either case, it’s very likely that a ½-watt resistor from a Radio Shack blister pack will deflagrate in the process.
Increase the resistor by a factor of 100. Even 50,000 ohms across 240V is a power dissipation of ~1.2 watts, which will cook a ½-watt resistor if left connected for any significant amount of time.
This makes a mockery of kilovolt-impulse withstands in IEC-1010 overvoltage categories, for use with multimeters on all but the smallest of power circuits.
[This message has been edited by Bjarney (edited 03-30-2004).]
#36051 03/31/04 04:57 AM
Point taken if someone tried to use a 1/2-watt resistor.
The principle is still good though, and it wouldn't be hard to construct a little feed-thru box with terminals each end to insert between meter and probe leads. Inside could be a suitable series-parallel resistor bank of wirewound resistors.
#36052 03/31/04 09:28 AM
I carry a Tripplet 310 in the plant for general troubleshooting of control circuits, after all its free since the co provides and if it falls from a crane I don't see the loss, however if I have to go to the CNCs or any high energy circuit I go get my personal Fluke 87III.
