Electricians revenge
0 members (), 205 guests, and 12 robots.
#33779 01/28/04 05:23 PM
Poor Ryan, got his hands dirty.
That was pretty good Earl [Linked Image]
Ryan Jackson,
Salt Lake City
#33780 01/28/04 05:24 PM
I do not use tape or pretwist.
Use the WING TWIST from IDEAL and your connections will be good for a very long time.
Edward
http://www.idealindustries.com/wt/TwistOnWireConnectors.nsf
Thanks
Edward
#33781 01/28/04 05:45 PM
No tape except on sta-kon joints which I use quite often. Take up less space than wire nuts and more secure IMO.
#33782 01/28/04 05:55 PM
would you guys tape wirenuts in a motor pighead?
#33783 01/28/04 05:59 PM
I never have and I have had no problems.
I crank them on hard with my pliers they will not fall off.
#33784 01/28/04 06:07 PM
I generally tape wire nuts that are used on power connections if motors are in the cabinet. Why vibration, plus on a gas pump there are at times way more splices than the junction box can easily contain(don't blame me I don't size the equipment supplied by a manufacturer) so they get jammed in there. When you come back to troubleshoot its helpful if stuff doesn't fall apart when pulling it back out.
#33785 01/28/04 07:44 PM
I use tape only when making 600V connections. I agree, it's not entirely necessary, but, I feel its good practice anyway.
Sandro.
#33786 01/28/04 08:36 PM
I thought you only needed to tape wire nuts when you bury the box [Linked Image]
J/K ...I know.
#33787 01/28/04 09:59 PM
The tape keeps the electricity from leaking out.
#33788 01/28/04 11:26 PM
..We use the Ideal,.."Tan" nutz, and although we DO pretwist,we don't tape..The only thing I want taped is the device, if it's in a metal box,..otherwise, my wire nutz are "tapeless'...
AR
