Electricians revenge
0 members (), 161 guests, and 10 robots.
#31561 11/26/03 02:55 PM
Sadly, I can see where this could become the "ultimate setup".
If they'd splice both ends of the (#6, maybe) conductor to a piece of #12 that could be terminated properly to the receptacle and the C/B...S
#31562 11/26/03 03:54 PM
I don't see the sadly in that last setup.
Some #6 in the wall, spliced (in a box and in the panel) to some #12, protected by a _20_ A circuit breaker, going to a single duplex receptacle. Hell, you could change the 50A double pole breaker to a 15A double pole breaker, and wire the duplex as a multiwire unit. The #6 wire would be wasted in this application, but it would remain exactly where it would be needed should the home-owner ever want to go back to an electric stove. I don't believe that the oversize wires themselves would present a problem; presumably the original stove receptacle box was properly sized for the #6 conductors....
-Jon
