Greg:
Could it be the 'missing' "only" in the side wire spec. The 'push' "only" is definitive and straightforward.
As I did primarily comm work, stranded was common. Termination was 85% on spec grade devices with the screwplate side wire. The other 15% technique was the small piece of insulation on the tip of the conductors. Never used a sta-kon.
