Swimming pool pump
by gfretwell - 03/29/23 01:01 PM
Using THWN on automotive circuits
by BigB - 03/23/23 11:19 AM
Continuous load
by HotLine1 - 03/08/23 02:11 PM
How's all our Non-US folks doing?
by dsk - 03/08/23 11:56 AM
Old Computers?
by Bill Addiss - 03/04/23 05:06 PM
Burger King crown sillyness
by wa2ise, December 11
240/208 to a house
240/208 to a house
by wa2ise, October 9
0 members (), 48 guests, and 12 robots.
#31021 11/06/03 11:38 AM
aldav53 Offline OP
If a 50a 240v outdoor spa has the GFI on the plug, can I run the circuit not using a GFI breaker?
#31022 11/06/03 01:07 PM
I believe if you feed a gfci device with another gfci device it will nuisance trip.
The gfci plug or disconnect should suffice which will be fed by a 50 amp dp breaker.
Edward
Thanks
Edward
#31023 11/06/03 02:03 PM
moved to NEC Area >> here
Tools for Electricians
2023 NEC Now Available!
2020 Master Electrician Exam Preparation Combos
2020 NEC Electrician
Exam Prep Combos:
Master / Journeyman
Admin
Admin
NY, USA
BigB 3
jt7 2
305,205 Are you busy
233,574 Re: Forum
218,242 Need opinion
