0 members (), 1,365 guests, and 11 robots.
Page 3 of 4 1 2 3 4
#28358 08/22/03 08:35 PM
F
As soon as it's dark I'm going back to that site to see the difference.
#28359 08/23/03 06:37 AM
Wow! Anyone not familiar with the outline of North America could be forgiven for thinking that there's another huge bay there!
#28360 08/25/03 07:54 PM
This photo has been called a fake on another site. Do you know where it came from? If not I will try and verify, and get back to you.
#28361 08/25/03 07:57 PM
A pretty lousy fake at that.
What is the blob of black extending out over the Atlantic ocean?
Why is the blackout area BLACK, when dark land and water areas are various shades of dark blue?
#28362 08/25/03 08:13 PM
Yup... If you can believe Snopes it's a fake. Their description makes sense.
http://www.snopes.com/photos/blackout.asp
Barbara Mikkelson at Snopes seems to make extra effort to preserve their credibility, including updates and occasional corrections/retractions as necessary.
[This message has been edited by Bjarney (edited 08-25-2003).]
#28363 08/25/03 08:53 PM
If I wanted to make a fake blackout picture like this, I would, using say Photoshop, select the appropriate area with the lasso tool, feather it a little, and adjust down the contrast not to zero but to around 5% and adjust down the brightness to that of the land in northern Canada. To simulate car lights and emergency lighting in the blackout areas.
#28364 08/25/03 08:55 PM
[Linked Image from 65.108.216.53]
#28365 08/25/03 10:13 PM
Ron Offline
Ron
#28366 08/26/03 12:17 AM
This may sound kind of silly... and straight out of the X Files
(and a little touch of Dale Gribble [Linked Image]...)
but I first thought the problem was Induced Currents from intense Solar Flares, causing transient surges and other fun things.
Believe this happened once before on the East Coast, and killed power for many hours across several states - including New York.
Feel free to fire away with straight jacket jokes if needed [Linked Image]
Bjarney, does this sound feasable? (not the straight jacket [Linked Image]...)
And if possible, would this either cause or assist in a Sub Sync Resonance situation going really bad?
Possible to throw excessive levels of Reactive Currents (or true power currents even) between Transformers?
Would something like this also interrupt or otherwise knock off-line the PoCo's Carrier Current monitoring and / or control systems?
Just hanging out with Fox Mulder...
Scott35
#28367 08/26/03 12:49 AM
Here is a link that relates to the solar flare thing. I will try and 'unlock' it to answer your question.
http://www.badastronomy.com/phpBB/viewtopic.php?t=7453&start=0
Page 3 of 4 1 2 3 4
