1 members (Scott35), 438 guests, and 9 robots.
#27637 07/27/03 07:41 PM
[Linked Image] well shoot partner,i thought it would stop the meter all together. not only is it ilegal,it's down right dangerous [Linked Image]
#27638 07/27/03 07:52 PM
almost forgot, GOOD LUCK LONESTAR!sounds like you've got a real nightmare on your hands.just looking at that would have made me say "no thanks."keep us posted! [Linked Image]
#27639 07/27/03 07:59 PM
"Strapping" or applying a jumper from line to load sides of the meter, creates a parrallel path for the current flow, part going thru the meter & part of it thru the strap or jumper. This is illegal & an unsafe practice... In Massachusetts the utilities are allowed to estimate the stolen energy & bill for triple the cost.
As for the meter running backwards with no load. This is creep & the disk should only roll back a patial revolution, until the anti-creep holes react with the retarding magnets & stop the disk. If the meter creeps backwards ir usually means the meter is slow under a light load, & if it creeps forward it is usually fast under light loads. Most utilities calibrate mechanical electric meters to be within + or - 0.5%. I have tested 50 - 60 years old meters that were still within this accuracy window.
