Thanks electric guy, Teck cable is going to be the answer,I think I am still going to have to bust out the pipe though. one more question for you, He had it set up to be fed from a cable drop from the ceiling (Its right in the middle of the floor. I think this is fixed equipment and should be run in pipe or I should at least run the teck cable supported(i am thinking of putting uni strut up) and then going to a disconnect first. I think his plan was to drop into a four square box on top of the conduit stub and just run cord and plug.I know its hard to visualize without pics, I am going to invext in a camera. Thanks very much for your time
Mike
