Electricians revenge
1 members (Scott35), 152 guests, and 14 robots.
#26077 05/29/03 10:58 AM
Hello
I have an equipment room with multiple power sources fed from seperate utility transformers. I have to bond a lot of gear in the room and my question is where should I get my ground? Building steel?
The room has many communications/server cabinets in it and I want them all bonded to ground. I know how I'm going to get to the ground once I find it but I want to make sure I select the proper path to earth.
Thanks in advance
#26078 05/29/03 11:31 PM
(moved to NEC Forum)
