555
33
I thought they were joking, but check this out http://wombatnation.com/blog/stories/incinolet.html [This message has been edited by wocolt (edited 05-15-2003).] [This message has been edited by wocolt (edited 05-15-2003).] [This message has been edited by wocolt (edited 05-15-2003).]
...(coffee filters just won't do)
Came across one at a telco microwave station. Only trouble was, it was in a room with a 750kW genset, and a large notice on the door warning that other similar generators had ejected metal engine parts through the outer housing during routine operation.
Er, now that's High Pucker Factor.
the crack research staff. Are you sure they are not kidding? edit, forgot not [This message has been edited by iwire (edited 05-15-2003).]
These actually work quite well. You don't want to be down wind from the vent while it's in operation!
I like the original better
They actually have a 240 volt version, he he... serves 8 people ..??? I guess it takes about two hours to work, can you imagine a family of 4 in the morning ... this is too easy.. dont think the Plumbers have anything to worry about for awhile.
I see no Plumbing Code approvals stated anywhere on their website. The product has a 30 day satisfaction guarantee, as long as you don't use it????????
Steve
Would something like that NEED plumbing code approval? Uses no water, and needs no waste line...
Have used one of these once at a remote mountaintop transmitter site. They work, but they STINK when the heater kicks in....
