192
14
Posts: 2,236 Likes: 1
Ewwwwwwww! lol
Price per stop, $25 to $30
[This message has been edited by sparky66wv (edited 07-11-2001).]
66' may get jealous, but here goes 1. $1000, I don't use entrance cable. 2 Same price & I'll give you the telephone # of someone who will do the repair better & cheaper than I could do it. 3. I only do these for friends, I hate ceiling fans. 4. Ditto 5. $33/hr one hour minimum plus 34 cents a mile. Time starts at the end of my driveway, ends when I get back. If the customer offers to help, $66 an hour. 6. Commercial & light industrial about $2.50 to $3.00 per foot based on my records. Service voltage & lighting package can have a big impact on this price as can a high amp service on a small building.
1)Ammended...I just did a 200A mobile home (double wide) service. Overhead 10' GRC mast, 50' of 2" PVC to panel. 60' of Tri-rated cable. 45' of Tri-rated single conductor, 2 g-rods (bent ) 2 LB's and a 90, hung with Min-E's on caddy beam clamps... No SE Cable... All Pipe... Cost less inspection, $599. Customer supplied the Feed-Through Disco (read-used). Had to use several plugs for it though... [This message has been edited by sparky66wv (edited 07-11-2001).]
My last post might help explain why I'm full of the stuff. Do any of you use combination/all in 1 services?? Are these at all common in the East & Midwest? I've only seen meter pan w/ the MB/panel inside in your pics.
[This message has been edited by electure (edited 07-11-2001).]
We use many meter/main combo's due to the meter position having to be under the gable end of a home per the utility, i guess there's been a few meter readers lost until the spring thaw. which is usually a bad location for the panel inside, for one reason or anotherThen there are the service laterals to mobile homes, all pedestal deals , combo units. Try and find 350kcmil lugs meter/ main combo, underground rated for $250-$300, and if the utility wants a bypass add $ 100, that's just the meter! [This message has been edited by sparky (edited 07-11-2001).]
[QUOTE]Originally posted by Tom: [B] 5. $33/hr one hour minimum plus 34 cents a mile. Time starts at the end of my driveway, ends when I get back. If the customer offers to help, $66 an hour. Reminds me of the contest where 1st prize is a week in Phila. 2nd prize is 2 weeks.
Posts: 4,116 Likes: 4
Electure,
We use Meter/MB combos here where the Panel is located a distance away from the point of SE entry. Utility requires a Bypass in the Meter so a 200A (single phase) unit sells for between $400 and $500. (just the Meter and Main Breaker Combo)
Redsy, Originally posted by Redsy: Same as above, except flush mount in drywall with average cutting/patching. Do you patch and spackle too? Paint? Bill
1)$850.00 2)$1000.00 3)$200.00 4)$350.00 5)$40.00/30.00 6) New residential-$750.00 for 200A ug serv w/o disconnect. $27.00 per opening, customer supplies fixtures. TV & phone- $20.00 per opening I supply jackplates. I only do custom homes, no tract.
Bill, I meant branch C/B's also. I think it might be weather. I can't imagine having to go outside in the freeeeeze. Ours are a complete unit usually. Weatherhead, mast, meter, main, branch c/b's within a linear space of 10' or so.
