0 members (), 303 guests, and 10 robots.
#24044 04/02/03 08:36 PM
Troubleshooting job resulted in the discovery of this poor varmint.
[Linked Image from users.stargate.net]
The switches the mouse was caught between were on two different circuits with opposite polarity, so 240V was possible here...
The problem was unrelated to the mouse.
[This message has been edited by sparky66wv (edited 04-02-2003).]
-Virgil
5 Star Inspections
Member IAEI
#24045 04/02/03 08:42 PM
How did the mouse get into the box? No cover plate?
Peter
#24046 04/02/03 08:52 PM
Mice can fit through VERY small openings. Thats got to suck!
#24047 04/02/03 09:08 PM
Hey! Why aren't the switches grounded?
#24048 04/02/03 09:27 PM
I have seen that before. Once in a meter socket where there was a whole family of them all got zapped. It was time for a new service.
#24049 04/02/03 10:11 PM
Speaking of rodents, how is it that squirrels can eat the insulation off romex untill you're left with 3 bare pieces of copper? They don't die and must enjoy it because they continue to do it. I once opened a wall and found 6 feet of bare wire that was romex along with nesting material.
#24050 04/02/03 10:20 PM
CRW Offline
Re: grounding the switches--the center one looks grounded at least, can't see the ECG terminal on the others.
I've seen a mouse get into a light box with a porcelain keyless fixture somehow, and that was in Chicago with a conduit system. Zapped, burnt, and blowing out bulb after bulb till we checked it out.
I found a birds nest with newly hatched birds in a outdoor box--CBs and GFI receptacles at a campground. That actually happened a couple times, found numerous eggs, nests, etc. They came in through an open KO on the bottom. Actually I prefer an opening on the bottom to allow water to drain out, but not to let critters in. Wasp nests are the worst.
#24051 04/02/03 11:17 PM
F
I found one of those things dead, with the tail end hanging out of the top of a trough that had a missing k/o, in a juice plant a few years back. I removed the cover and found the creature still had his jaws wrapped around a live 480 volt motor feed wire. YUCK!!!!!!
#24052 04/02/03 11:36 PM
The only "critter" I have come across was a mouse that made a home out of the buildings Walker Duct system. I was doing some demo and he was permanently attached to the hot terminal of a receptacle.
#24053 04/03/03 12:05 AM
[Linked Image from 65.108.216.53]
