Electricians revenge
1 members (Scott35), 179 guests, and 6 robots.
#23623 03/24/03 11:04 PM
While an LB or "T" is merely a fitting, if it is exposed after all the finish work is completed by others, it qualifies as a pulling point. Does it not?
bob
#23624 03/25/03 06:35 PM
What a mind melt in regards to what a "Fitting" means in different parts of the USA!!!
Like Nick and Electure, "Fitting" means "Coupling" or "Connector" to me, and must be a "California Thing"???
If I asked someone for a "_____" Fitting and that person returned with an LB/LL/LR/C or T, my head would be spinning!
(fill in the blank with an example fitting)
On the flipside, if I was on a job with people from other States and was asked to get a certain size fitting, when returning with a Coupling or Connector, that person may seriously doubt my trade experience and knowledge!
I need to remember this thread for future "Termology Debates / Issues" [Linked Image]
Scott35
#23625 03/25/03 07:21 PM
When someone started to enforce the deduction for a "locknut and bushing" when calculating box fill, the result was the addition the following sentence to the 370-16 or 314.16 code:
"No allowance shall be required for small fittings such as locknuts and bushings."
