0 members (), 152 guests, and 22 robots.
#22760 03/04/03 09:33 PM
Bill,
Here in NJ the state makes me do a visual inspection every year that a community pool opens up. It is a non effasive type of an inspection. I look for loose wires, connections, new equip., no loose bonded equip., and test GFCI's. If something doesn't look good, then I can require another "Bonding" inspection. This bonding inspection happens to all public pools in NJ. The get tested every 5 years. A contractor would come in to this pool, and test resistence between all points. He has to be satisfied that it is below a safe potential. The makers of pool and pool equipment also make the meters that are used for this test. If you want info about the test, let me know.
Harold
#22761 03/05/03 07:35 AM
chuck Offline OP
Thqanks Harold, This info would be a help as we are getting prepared to do community pool testing for our county. A maajor controversy in our area stems from the fact that almost all the above ground irregardless of size are not bolted welded or screwd . Many parts snap fit together and since the code says NO bonding or grounding with sheet meat screws it is nearly impossible to do.
#22762 03/05/03 10:46 PM
Chuck,
Check your e-mail. Harold
#22763 03/07/03 04:04 PM
SJT Offline
I like that method of the 10/32 tap and the stainless steel screws. That would satisfy the code. I know I'm guilty of using the #10 sheet metal screws into every other upright.
We have to keep the solid #8 on hand for the summer months. Also I would scotch-cote every bonding, lug connection.
#22764 03/11/03 08:39 AM
Harold
I would appreciate a copy of your pool testing information.
TIA
Coachman
#22765 03/11/03 06:00 PM
Harold
I would appreciate information on pool testing.
Thanks
#22766 03/12/03 11:28 PM
Coachman and JerryF,
If you E-mail me with a fax number, I will send you the info that you are looking for. My state is requiring that any public pool get a bonding and grounding certificate every 5 years, and I do ( as the AHJ ) a non-invasive inspection every year.
