1 members (Scott35), 521 guests, and 40 robots.
#2255 06/29/01 07:37 PM
F
frank Offline OP
what will happen if you lose the shunt field
on a dc shunt motor
#2256 06/30/01 11:00 AM
on a dc shunt motor
I think it will overspeed. Generally, there is a field loss relay in series with the field that would open the control circuit if it were to drop out.
#2257 06/30/01 01:02 PM
F
frank Offline OP
ok good because thats what i put on the exam.
i no a series motor will overspeed but i was not sure about a shunt thanks
#2258 09/02/01 08:48 AM
If you oopen the field switch to a shunt motor if will take off and self-destruct, this is why they put a field-loss relay in the control circcuit to prevent this from happening.
