0 members (), 239 guests, and 12 robots.
#222864 06/20/25 11:18 AM
This showed up on Facebook with someone suggesting it was a good way to add a bathroom to a utility room.
[Linked Image from gfretwell.com]
Don't know about the US but from my local perspective I can't really see anything explicitly non-compliant. Safe zones are only required for showers and baths, not sinks or toilets.
The most glaring violation is working space around those panels but you are are dealing with "foreign systems" and the fact that over current devices are not allowed in bathrooms.
Look at the bright side: At least they didn't the GEC (ground the service) to the plastic pipe!
Now, just to play devils' advocate:
I see concrete walls, suggesting this toilet in the basement. Many older homes have a simple toilet and sink placed openly in the basement - without any privacy walls whatever. These toilets are a carryover from the times where guys would return home from horribly dirty work and change out of their work clothes before ever entering the house.
Without defining walls, can you fairly claim the entire basement is a "bathroom?" That seems absurd.
Yeah definitely would be a working space violation NEC 110.26, as far as being in a bathroom that ban in 240.24(E) was only dwelling unit bathrooms, until recently when it was expanded, while the working space requirement makes sense,
I am not so sure the addition of the commercial bathroom (with no shower) improves safety.
I there is a chain convenience stores that ad all their electrical panels in the bathrooms as there was ample working space, did not tend to get cluttered, and the room was normally locked from the public.
Now they put the panels in the store and roll a fridge case in front of them LOL
I am sure across the pond BS 7671: 132.12 and IEC 60364-5-52 would say something that install also? Can you have a 'consumer unit' (aka load-center) in a lavatory?
I don't know about the UK but I'm fairly sure that in Germany and Austria only the safe zones around showers and baths preclude distribution boards. The rules for metering equipment are very different and much stricter, especially in Germany.
