0 members (), 1,735 guests, and 18 robots.
I have an older home with one of those lighted address plaques with the Better Living Thru Electricity emblems on it. The sockets and bulbs have seized. Was hoping to find some of these dual sockets (there are two dual sockets, total 4 small E10 bulbs). I am not finding any, but maybe Im calling them the wrong thing - or they simply do not exist anymore ;^)
Worse case, convert to LED? If I have to go that route, how can I attach old school low volt screw connected to modern LED stuff? Going to push to find the old ones but afrai they might be very specialty. Especially the way they are rivet connected from top. They are actually sort of collectible, with some cool history. Thought they would be easy to obtain (ebay, etc) but not so much.
All thoughts welcome, and appreciated.
That is also called candelabra or miniature. Amazon may have what you need
amazon
They also have the bulbs, I am guessing 12v.
Like a lot of things you can buy a couple dozen for the price of 2. You are paying for the package.
Now that you know what you are looking for Home Depot may have them.
Oddly enough . . . I’ve found a decent replacement at my local grocery store!
The store sells some 120V LED fixtures that are 12” long and 1-1/4” tall. They look like they’d fit under that top trim. It also looks to me that the bulbs are receiving 120V power. It shouldn’t be too hard to remove the old and mount the new.
The direct wire LED "florescent" tubes make fixing bad ones or simply making new ones, real easy.
"We don't need no stinking ballast" wink
Those lamps are either single, or double, contact bayonet base lamps, what voltage? LED conversion makes so much sense these days though.
The ones I buy use 120v directly into the lamp (Feit). You remove the ballast and direct wire into the tombstones.
I assume they also make a 277v version.
It does make lighting become an insignificant part of your overall load. The newer ones also have a 5 position switch to select your color. In the garage I am OK with 6000 but I like 2700 or 3000 in most places in the house
