Non-Contact Voltage Testers Recalled by Klein Tools Due to Shock Hazard:Recall Date: June 9, 2021
Recall Number: 21-150
Recall SummaryName of product:
Klein Tools Non-Contact Voltage Tester Model NCVT-1
Hazard:The on/off button can remain depressed during the power on or power off cycle, causing the tester to work improperly. Consumers testing electrical sources could fail to be warned of the presence of live voltage if the tester is not properly operating, posing a shock hazard to the users.
Remedy:Replace
Consumers should immediately stop using the recalled non-contact voltage testers and contact Klein Tools for instructions on receiving a free replacement tool.
Consumer Contact:Klein Tools at 800-527-3099 from 7 a.m. to 6 p.m. CT Monday through Friday, email at ncvt1support@kleintools.com or online at
www.kleintools.com and click on “Safety Recall Information” at the bottom of the page for more information.
Pictures (and more info) available here: https://www.cpsc.gov/Recalls/2021/N...alled-by-Klein-Tools-Due-to-Shock-Hazard Recall DetailsUnits:
About 1,690,000 (In addition, about 67,800 were sold in Canada.)
Description:This recall involves Klein Tools Non-Contact Voltage Testers with model numbers NCVT1 and date codes ending H7. The product was also sold separately and in kits.
The meters have a yellow body housing with a tinted gray tip and have a black pocket clip/battery cap on the back. The part/model numbers are written on the top of each unit above the brand name KLEIN TOOLS and date codes are printed on the bottom of the unit under the brand name. The product is rated CAT IV and measures voltage up to 1,000 Volts.
Incidents/Injuries:Klein Tools has received two reports of incidents of the voltage tester not working properly, including one shock injury.
Sold At:The Home Depot stores and industrial distributors, electrical wholesalers and some hardware stores nationwide from January 2020 through March 2021 for about $17 (for units sold separately) and about $40-$68 (for kits).
Importer(s):Klein Tools, of Lincolnshire, Ill.
Manufactured In:China
