Eaton has identified a potential nonconformance that results in an exposed, 42 AWG wire (0.07 mm diameter) used in the indicating circuit of the CUBEFuse. The indicating wire may be
exposed to the front or back of the fuse, thereby eliminating its finger safe characteristics.
Any nonconforming CUBEFuse will still interrupt overloads and short-circuits.
(see attached)
Attached PDF document
