1 members (Scott35), 161 guests, and 30 robots.
Just wanted to add some specs for POTS (Plain Old Telephone Service)
**** "(NOM)" = Nominal, or Typical; "(LIM)" = Limits ****
On-Hook Voltage:
48 VDC (NOM), 4 - 105 VDC (LIM),
Off-Hook Voltage:
6 VDC (NOM), 4 - 105 VDC (LIM),
Operating Current (Also Known As "Loop Current"):
25 ma (NOM), 20 - 120 ma (LIM),
Telephone Set Resistance:
300 Ohms (NOM), 100 - 400 Ohms (LIM),
Subscriber Loop Resistance:
0 - 1300 Ohms (NOM), 0 - 3600 Ohms (LIM),
Loop Loss - In dB (deciBels):
8dB (NOM), 17dB (LIM),
Distortion (THD):
- 50dB
Ringing Frequency:
20 Hz (NOM), 16 - 60 Hz (LIM),
Ringing Voltage (RMS):
90 VAC (NOM), 40 - 130 VAC (LIM)
Ringing Current (RMS):
20 - 50 ma
Maximum REN (Ringer Equivalency Number):
5 REN (total of all sets not to exceed 5)
-suffix "A" devices ring @ 20 Hz,
-suffix "B" devices fing at any Hz.
Bandwidth: 3 KHz (180 Hz to 3.2 KHz)
Signal to Noise Ratio (SNR): 45dB (apx.)
Signal Levels - Average (at Tip / Ring): -9dBm (normal speech), +4dBm (peak speech)
DC Supply Is Positive Earth Grounded (the "+" side is grounded), so system is normally referred to with respect to Ungrounded Polarity - such as:
" -48 VDC "
"TIP" = " + " Polarity, "RING" = " - " Polarity.
Color Code (Simple Examples):
"Level 1" / "JK Cable":
TIP = Green, RING = Red
Multi Pair Cable (i.e. Level / CAT 3, CAT 5, etc.)- 4 Pair Cable Listed Below in first examples:
Pair #1:
TIP = White / Blue color band (stripe),
RING = Blue / White color band,
Pair #2:
TIP = White / Orange color band (stripe),
RING = Orange / White color band,
Pair #3:
TIP = White / Green color band (stripe),
RING = Green / White color band,
Pair #4:
TIP = White / Brown color band (stripe),
RING = Brown / White color band.
If Cable Has 5th Pair:
Pair #5:
TIP = White / Slate color band (stripe),
RING = Slate / White color band.
Pair Colors Passed The 5th Pair - Upto The 25th Pair:
(swap "White" listed above for Pairs #1 thru #5 with color listed below)
Pairs #6 thru #10: Red,
Pairs #11 thru #15: Black,
Pairs #16 thru #20: Yellow,
Pairs #21 thru #25: Violet.
I can add more if needed, or include Telephone relavent data (such as this list, plus more advanced details) in the Technical References section.
Let me know what sounds good - and if anyone can assist with documents.
Scott35 S.E.T.
So to get in, you called the radio station from the pay phone next to the door. and when you heard the phone ring, the door unlocked. No body ever figured out how we were getting in.
That's an expensive key if you add up all of the phone calls!
As I said, we were college students. We called collect!
Scott35:
Thanks for the data--please do post what you can. I very much appreciate the reference material you (and others) make available!
pauluk:
I'm not quite sure what you're getting at with taking resistance readings on a live line though. If there's TelCo line current flowing,the meter reading will be meaningless. Or did you just mean would the meter be safe if you accidentally connected it to a live line?
Yes and no [Linked Image]
What I am trying to do is to figure out where an imbalance (unbalance?) might be. That would be more along the lines of capacitance rather than resistance, right? I guess that's more of a job for a TDR (with a pro operating it...) rather than a DMM. Either that or one of these ...
Well, I took some readings just out of curiosity and one was quite interesting:
KHz, ring-to-ground, was 770.
That's WABC talk radio, the station that is heard on the phone line [Linked Image]
Scott,
I started out my career installing burglar/fire alarms and we had one type of a system called a "BA" alarm. The central office would send out 130 volts DC over the phone line to our control box. The readings you got back told us if the alarm was off/on/ or in alarm. That 130 VDC would really sting if you got nailed by it.
Harold
