Electricians revenge
0 members (), 169 guests, and 7 robots.
HotLine1 #209874 05/09/13 12:49 PM
Hi,
I misquoted the following post:
"Idrive a ground rod run #6 to meter base this is the GEC correct? The GEC is run with circuit conductors..an equal potential grid is a grounding mat/grid connected to ground rods..for the whole plant they have 4/0 in the ground and #2 insulated ground for grounding tanks, motors or building steel..thanks for the replies.."
I meant to say: "drive a ground rod run #6 to meter base this is the GEC correct? The EGC is run with circuit conductors..an equal potential grid is a grounding mat/grid connected to ground rods..for the whole plant they have 4/0 in the ground and #2 insulated ground for grounding tanks, motors or building steel..thanks for the replies.." sorry for the confusion and thanks for the correction!
Don't drive and TEXT! Drive now TALK LATER!
akmaster #209879 05/09/13 03:20 PM
No problem! That's why we are here.
