0 members (), 768 guests, and 10 robots.
OH & UG are factors
Meter only or Meter/Main is a factor
OCPD upgrades (to AFCI's) are a BIG factor
"Old Service Station" and "Painting" both bring some scary thoughts to mind. [Linked Image]
Changing out a load center shouldn't be a big chore..4-8hrs total, but be sure of what the intentions are for its new use.
MinElectrcn, welcome!
(BTW, all CAPITALS are quite hard to read, and are generally considered as yelling.)...S
WEll guys my nice easy panel swap wasn't too bad just a few things they forgot to tell me because they didn't know is that its 3phase and they want single.
So went out saturday to get started after my buddy picked up a new 200amp SQD panel and i said hey ben this is 3phase. My dad said he had it change to single ah no he didn't.
So my simple panel swap turned into a complete new service drop weather head, meter box, wire, and all after.
got everything in today hoping the utility will come back tomorrow and turn on. I took day off work to do this for my buddy i told him its going to cost more than what i first told him, which isn't much he is a good friend, still need to run all ckts and put in some new romex.
Ben, Just a quick question. How did you "look" at the panel and the feeder and not notice that it was 3 phase? Did you even take the covers off when you estimated the job?
no i didnt look it over very well or take off panel, like i said this guy is a good friend and has done a lot of custom paint jobs on my kids dirt bike and other stuff so it was a favor to a friend kind of job. i owed him some favors now he owes me some more and a few bucks to boot. I am sure all of you have done this somewere along the line.
Knowing how to do electrical work will get you friends you didn't know you had!LOL
Donnie
F
ahh here in north eastern wisconsin it typically over a thousand dollars for 200 amps ( single phase ) service and the manfacures i use is C-H prodits and sometime SQD also depend on what it is set up for but for three phase service it varis depend on set up due trois phase breakers (3ph) cost pretty high !!!! [Linked Image]
hay txsparky my travel plans are all set i will be in texas next wed and thur 12th and 13th,
I have to fly to chicago tuesday the 11th to interview for another position for field service in ohio but the interview is in chicago. Its going to be an interesting week
jhmaint,
Good Luck with your interviews.Hope everything goes your way.
P.S.-My sister is city parks administrator in Chicago.Cold and windy there!!!She can have it. [Linked Image]
Donnie
i would give yourself about 7 total hours. this includes all travel time and buying time. the total job should cost around 900-1500.
triple 3
590,046 Are you busy
467,455 Re: Forum
427,889 Need opinion
