184
13
I honestly can't say if there is a poop factor involving GFCI's. if any pre-smart GFCI's still pass with hitting the "Test" button, its good enough to keeps its UL listing so it should still be good. Granted, to also maintain its listing, it has to be used IAW the manufacturer's instruction so in sure every home owner that has a GFCI are testing them weekly...
Posts: 9,935 Likes: 34
I agree with Sparky. The test button is the determining factor on whether an AFCI or GFCI is still working. If test trips it and reset resets it the device is working, at least as far as a user can tell. I can think of no reason why time changes the operation. It is not like a radioactive sensor in a smoke detector that can just get old or a sensor chamber that can become contaminated over time.
There might be an argument made that replacing older technology devices with a newer one was worth doing.
It's been a few years but when I looked into the whole Smart GFCI thing, UL was stating that it was OK to use up existing stock of "old" GFCI's and there was no time limit or deadline. If it still tests good, it's good enough for me
I do wish folks would stop drinking the Kool-ade ...
The test button is NOT the 'determining factor on whether a GFCI works. GFCI's work using a rather simple principle, one that is readily duplicated using simple test equipment. One need not rely only on the test button. (Leaving circuits without ground wires aside).
The statement is correct regarding AFCI's, for reasons that are becoming plainer each day. The primary reason you can't 'test' and AFCI with any certainty the test is any good is because the things are NEVER tested against any sort of an arc.
I will submit the opinion here that science demands that features be readily tested anywhere, anytime, by anyone with repeatable results. Relying upon the 'test' button is a sham- for all we know, the device is a fake and the button but a switch.
I also submit that we should NEVER mention GFCI's and AFCI's together, as if they have anything in common. To do so only sheds doubt on the GFCI.
I agree Reno. However, I dug into this a few years ago because my tester sad it was bad and the test button ssaid it was good. As long its wired properly and the test button trips the device, its still considered good and safe even if a portable tester doesent trip it.
Besides, I like Kool-aid...
Posts: 7,383 Likes: 7
We chech GFIs with a bugeye tester, and AFCI with the 'test' switch on the CB. We tried a AFCI 'tester' which did not provide satisfactory results.
The 'tester' is/was marketed as an 'indicator' or something similar. It lasted for two (2) operations and failed due to what the tech described as component overheating. The device was 'not rated' for repetative operation, it requires a 'cool down' between uses. Returned to the supplier for refund, as it turned out the units were on recall or something.
