0 members (), 1,379 guests, and 10 robots.
Is there any software out there that can simulate complex control circuits so the the logic can be tested before construction?
twh Offline
If it's complex enough to use a programmable relay, you can test with the programming software.
I was wondering about PLC software. I'm not using PLC's for various reasons. Would I be able to purchase and use the software as a simulator without a PLC? Any suggestion on user friendly software?
twh Offline
Here is a link to zelio:
http://zelio-soft-2.software.informer.com/
I'm on the wrong machine so I'm not 100% certain of the link. The software is free and the smallest relay is about the cost of a couple TDR's, so it's reasonable.
I have used another make, but they charge for the software.
Thanx!
Tom Offline
You can also try Automation Direct, free software (Click), a Click PLC is about $70, you might need a small power supply if you don't have one. The programming is about as easy as it gets, I use it to teach ladder logic & PLC programming.
