0 members (), 630 guests, and 12 robots.
#205679 03/21/12 05:37 PM
I just had a call from a client that will be installing one of these on a bidet
he says it has a very short cord and needs a receptacle I assume gfci protected and I assume the bidet can not block the receptacle I assume it can be on the same circuit as the counter GFCI
has anyone wired for one of these yet ??
http://amdmllc.com/?page_id=330
He purchased it at costco
dougwells #205683 03/22/12 09:45 AM
Doug:
I have seen a few <4 of a similar item, don't know the brand name. They were installed with a direct 20 amp circuit w/GFI protection, based on the mfg instructions.
Installs were by the same EC; a single 20 amp recept, on a GF breaker.
The link to your unit does not appear to have any 'spec'; it mentions hot water, warm air, heated seat, etc. But no data.
Depending on the actual load, tie-in to the bath circuit may be an issue. I am not familiar with the CEC regs, so the ball is in your court.
dougwells #205684 03/22/12 12:51 PM
I been trying to find info on it also, I told the customer that it may require its own circuit.
dougwells #205685 03/22/12 01:57 PM
I called the Customer back, The wife had actually read the instructions the unit has a hot water heater and draws 700 W so it will need its own GFCI circuit,
dougwells #205690 03/22/12 06:31 PM
http://mybootybath.com/
Click it.
Then click the video.
Somehow I don't see this insta-hot load ever running at the same time as a hair dryer.
Anyhow, it looks like it could be a warm product. Every unit is going to need an electrician -- fishing Romex time and again.
Tesla
dougwells #205693 03/22/12 09:39 PM
Done, now I see what it is. They may be returning it to Costco the expense of a separate circuit was too much
dougwells #205694 03/22/12 10:01 PM
Doug:
<$500 for a 'toilet seat' & quibble over the professional installation cost?? Hope they don't just go & buy an orange extension cord!! LOL
dougwells #205695 03/22/12 11:05 PM
twh Offline
A water fountain for Rover.
twh #205696 03/22/12 11:13 PM
I never thought of that,:)
dougwells #205699 03/23/12 12:18 AM
Since I can't imagine this unit ever running at the same time as any other receptacle load in such a space...
( Think on it... )
I'd simply install a GFCI receptacle off of a lightly loaded circuit.
The 700 Watts are a joke considering the amount of time they'll be drawn.
I think these gadgets are going to make a big splash.
BTW, the warm seat is a huge seller.
It sells itself...
And flushes itself, too.
It also soft-closes.
These are the greatest gadgets since the disposal.
Tesla
