0 members (), 181 guests, and 10 robots.
Originally Posted by romex2121
per the 2008 NEC how many steps need to be present to justify a 3-way system,,, example 2, 4, 6,
3 steps in Michigan...
Shake n Bake
IRC requires switches even if a PIR is used. Because they can and do fail
That is the code run amok.
I suppose someone should point out, switches break and lamps burn out too.
pdh Offline
Multi bulb lamps, extra lamps, multiple motion detectors, and a bank of switches. Oh wait, also an emergency break-in box with a flashlight, and extra batteries. That should cover lots of breakage :-)
Do they have a wattage requirement, or can I use 4 watt bulb.
What about permanent step lights? Can I get by with just those?
I didn't see where it said 3-way. Can I use on/off contactors?
