Electricians revenge
0 members (), 41 guests, and 11 robots.
Originally Posted by ghost307
Did anyone else ever try the Saf-T-Brace?
It says on the box that it's made by Westinghouse but I've also heard that it's a product of Angelo.It's basically a box with a brace that wedges between the joists without having to gain access to the space above the box. It can be installed through the drywall cutout only.
Angelo Brothers (Abco) has licensed the Westinghouse name.....
The SmartBox Fan Box is a good solution when you're up against the side of a Joist, and it can be installed without going in the attic:
[Linked Image from licensedelectrician.com]
It's a plastic box, - it doesn't show in the picture above, but it has a hefty metal bracket up the joist side and across the top:
http://www.licensedelectrician.com/Store/SB/Images/SBFAN_Release.jpg
more info:
http://www.licensedelectrician.com/Store/SmartBox-3.htm
I got a free one of those boxes from somewhere. It does look like a pretty good product. That ground screw goes into the bracket and that also gets you into the fan mounting screws which go all the way through. (the nuts in the picture)
It is a sturdy box.
I used to do a lot of Fans back in the day, and used the expandable fan braces quite a bit. The installations that gave me the most trouble were where I was replacing a ceiling box that was mounted to the side of a joist. Sometimes you couldn't get the fan box close enough where a small Fan canopy would totally cover the original hole.
These boxes, being flat on one side, would have done the trick, and saved me a lot of greif.
