Electricians revenge
0 members (), 171 guests, and 31 robots.
I'm afraid there's no quick, easy, cheap solution.
One option is to have power to all the lights, all the time ... then have a timer at each pole, feeding a photoeye at each fixture, controlling each light. The drawback to this method is that every light will momentarily energize when the photocell is energized by the timer.
Your other choice is a better timer at each pole. That is, forget about 'dusk to dawn' and use an 'astronomical' timer. Such a timer is already programmed with sunset / sunrise times for each day, and will allow you to program a specific time 'off' as well.
Originally Posted by gfretwell
I have found some regular timers with electronic clocks that say they can hold the clock for up to 96 hours in a power failure. That might the trick.
The thing with battery back up devices is they are not typically design for multiple and or long power outages. For example a resi smoke alarm. The battery carries the device but can do it for about a total time of 8 hours and it does not recharge the battery like a fire alarm panel battery. It's is important to to see how the battery is used for the device. If the switch recharges the battery then that would be a great and economical option. A battery operated timer would require a regular battery replacement and it wouldnt be well liked by the customer
Also using any device in a way not intended may void the listing and warranty
Sparky That is what made the Paragon so attractive. It doesn't use a battery, it uses a capacitor that will take lots of cycles.
http://www.illinoiscapacitor.com/pdf/Papers/supercapacitors.pdf
The most significant advantage supercapacitors have over batteries is their ability to be
charged and discharged continuously without degrading like batteries do.
Cool. I need to keep that in mind
Update
The paragon worked and my wife's electrician thinks she is a genius. He is proposing it in other places now.
