0 members (), 1,094 guests, and 11 robots.
#202028 07/11/11 10:37 AM
Bravo Offline OP
Hello,
I have an existing emergency power dist. system with life safety & non-life safety loads. There is a requirement to add new life safety branch circuits. The existing emer. pwr system currently does not have overcurrent devices selectively coordinated.
Once we modify the existing system, is a coordination study required per NEC 700.27? The system was designed and constructed prior to 2005 NEC.
Thanks in advance.
Workgear for Electricians
dbravo:
I would discuss your situation with the AHJ in the town the project is in.
The extent of the mods you have to perform may be the deciding factor.
