0 members (), 775 guests, and 10 robots.
They preceded wire nuts with the spring. We still see them but are not very common any more. A better connector where vibration was an issue but the caps have been seen to loosen too.
Originally Posted by harold endean
twh,
is Marr a trade name or just a style of connector?
A customer happened to give me an old box of marrettes today
Interesting about the wire mixture , that was a new one to me
Doug:
Are those still available? The wire mix is really interesting to me. The word 'approved' is from a NRTL or is that the mfg choice?
They do not bear that wire combination anymore on the new ones. but if you look at jdevlin link from above Marrette now has # 63 and # 65 connectors that are certified for that wire combination.
oh here is a direct link
http://www.tnb-canada.com/en/catalogues/online/comresconstruction/pdf/c5/09_marrcat_e.pdf
Doug:
Thanks for the link!! I notice the 'not UL', but a 'CSA'
The only al wirenut I have seen is the Ideal Purple around here.
I remember seeing those setscrew connectors at the local hardware store when I was little. I only seen one once in the field, and that was in a motor's terminal box. Funny thing only one connection had the setscrew connector, the rest had wirenuts.
I know they list them in the current ideal catalog.
I tried to go out to jdevlin's web page, but I couldn't get through. It said the "file was damaged". Maybe I can search for it in another way.
TWH,
Even though I have been around electrical work for 30 plus years, and all the guys I talk to at the supply house, many have seen these types of wire nuts but few actually use them. The other thing is that you don't see them every day. You can go for months and and even a year or two then you see them again.
Doug,
I know that you have an old box there but I was just wondering, Are the still listed to use with AL to CU wires?
