Electricians revenge
1 members (Scott35), 184 guests, and 13 robots.
Page 2 of 5 1 2 3 4 5
very true Mike
etta> some folks use this sort of 'twin lead' uhmmm indicatorfor K&T>
[Linked Image from westernfenceco.com]
but what they do (you fellas are probably gonna spank me for this one) is hold one lead to a wire, while holding the other
the light glows, but just dim
~S~
I have held 1 end and touched the other to a live wire. Kind of a bad child of the swipe your finger over the bare end to see if it is live.
I can tell you a neon tester is no match for a High voltage transformer. Not even at the end of a wooden broom handle, wearing leather gloves with insulated boots on an aluminum ladder and only 1 end of the neon touching the live terminal, the other lead from the neon was in the air.
BTW it was a transformer for an electrostatic Air cleaner that did not seem to make the dust go snap. It made me go snap. I learned a few lessons about trouble shooting and high voltage that day. Fortuneately I survived to apply the lessons I learned.
~s~:
That looks like what I thought Greg was talking about, but a more 'modern' version. The guards and the long probes look like a modern touch.
This is a neon pen tester.
[Linked Image from gfretwell.com]
Greg:
I must say I do not remember ever seeing/using one of them.
in Europe (Continental) you can buy those in every supermarket and DIYers believe them to be actual accurate meters.
They are probably more reliable at 220v.
Although I never used them, I know what Ther are. Does that make me old?
Why they teach you not to put screwdrivers into receptacles, they make s gizmo like that. Go figure!
laugh
I've seen some of those screwdrives labeled 120/230V so they seem to be at least designed to work in the US too. They aren't known to be very reliable here though. I've never had a false negative, but apparently they're quite common. False positives most definitely are (dead conductors showing as hot).
So that is what that is. My Father-in-law had one and when he died none of his family knew what t was for. Hmm, I guess that I am just a know nothing engineer after all.
