0 members (), 1,160 guests, and 8 robots.
There is also a thriving industry around the computers making adapter cables wink
K
Originally Posted by harold endean
I don't want to keep harping on this issue, but look what happens when the manufactures write the NEC. They promote their own equipment. I feel the only place a manufacture is allowed to sit on a code making panel is when the section of the code refers to the construction of a piece of equipment.
Just my 2 cents.. smile (stepping off my soap box!)
Hmmm... you mean maybe something like they did with the AFCI back in the 2002 NEC, which said we would need to install them in bedrooms starting in 01/05? And then again mandating the change to C/AFCI’s as of 01/08 in the 2005 NEC? And now in the 2011, mandating the AFCI outlet device for extensions and modifications starting in 01/2014?
Yes, I too think I see a pattern developing here. whistle
The original CMP intent was to require them throughout the house back in 1999, but it was thought to have been too disruptive with a new device so they limited them to bedroom receptacle outlets. Then they expanded it to all bedroom outlets, then to more areas of the house.
Soon they will be exactly where they originally wanted to be in 1999, with everything in the house protected with AFCIs...and it only took us a little over 10 years to get there.
Ghost307
