819
8
No technology located in a circuit breaker or fuse panel could detect a high-resistance wiring fault, as no measurable characteristic exists that differentiates a glow fault from normal branch circuit operation. Power Fault Circuit Interrupters (PFCI) located in receptacles are designed to prevent fires caused by glowing connections in premise wiring or panels. From the receptacle, a PFCI can detect the voltage drop when high current exists in a high resistance junction. In a properly designed circuit, substantial voltage drops should never occur. Proper wire terminations inside utilization equipment (e.g. appliances, lamps, heaters) and cords prevent high-resistance connections that can lead to fires. Excess current can heat entire lengths of wire. Thermal circuit breakers are designed to protect against excess current through the permanent circuit wiring. However, excess current through the smaller wires in utilization equipment can exist, at levels below the trip thresholds of a circuit breaker. Overload fault circuit interrupters (OFCI) are designed to protect against excess current drawn by utilization equipment. OFCIs must be located within receptacles. Both thermal circuit breakers and OFCIs are required to prevent fire ignition from excess current. from wiki> http://en.wikipedia.org/wiki/Arc-fault_circuit_interrupteranyone ever heard of, or seen these devices ? ~S~
Posts: 7,413 Likes: 10
~s~: I recently saw something about a device (Duplex recept) that had some overload protection as selling point.
I can't remember where...possibly the 'lectricians toolbox site that I went to out of boredom! I looked thru recent posts here & do not see the thread.
It featured a 'glowing' termination on a screw terminal of a recept if I remember.
Later
Posts: 4,165 Likes: 7
Later Is this it? http://www.electrical-classifieds.com/27_fire_prevention_outlet
Bill: You do not cease to amaze me!!!
That's it!
Check it our Sparky
Posts: 5,485 Likes: 5
Just a caution ....
The "UL" listing is just for the device as a receptacle. UL has NOT evaluated the claimed protective features of the device.
Nor, for that matter, are they likely to ... until the technology is completely free from an patent/trademark protections, and the NEC recognizes it.
If that ever happens, I'll let you know ... I "know someone" on the appropriate committee.
That's it!
Check it our Sparky Nor I...good shootin' Bill Fact is, i'm rather fascinated Hotone, enough that i called a one Mr. Michael Strauss, Chairman & CEO (well i called and he was kind enough to call me back promptly) inquiring as to his new product link hereOne might recall the point of use debates that circulated when the afci debuted.... The interesting thing is, this product, apparently predicated itself via Joule's first law of thermodynamics> Product DescriptionThis device consists of multiple sensors which detect abnormal heat at each outlet contact and binding head screw terminal. When such heat is detected, the sensors activate, the load fully disconnects, and an indicator pin protrudes from the face of the device. The user can easily see that abnormally high heat activated the device, which is no longer functional – a feature that prevents further damage to the existing wiring. We recommend that a licensed professional inspect the fault condition and replace the outlet.So, instead of having Mr. Strauss spend his time answering to just one electrician, begging the induldgence of the moderators ,i've asked him here to explain it en masse' ( and Mike, if you can sell this crew, your in like flint!)~S~
Posts: 8,450 Likes: 4
Just a little thing about terminations at fittings themselves. Now I'm not trying (or willing) to put the boot into the way things are done in the US, but I've never really liked the idea of the "wire under the screw" method of connecting a wire to a device.
Having said that, I don't have a problem with it per se, where an electrician that does heaps of these connections every day of the week and can just about do it with their eyes closed and with the proper tools. But, when you get someone doing their own electrical work at home, there is a chance the copper could be nicked or some of the copper wire stripped away, resulting in a lower integrity connection with the screw and a higher resistance connection. Or you have the person that winds the wire around the wrong way and it moves out from under the screw as it is tightened. For this reason alone, I prefer the tunnel type terminals we use over here, they are virtually fool-proof.
I do however, like the concept of the receptacle that Bill linked to, a LOT of energy is dissipated at bad connections.
Trumpy: FWIW, we have 'tunnel' terminations on devices here, on 'specification grade' devices.....which are premium $$ priced. They always were my 'choice', and were great with stranded conductors. Keep in mind also on this corner of the world, the NMC is solid conductors.
That's it!
Check it our Sparky LOL! Well, maybe some disclosure is appropriate here.... I've got one on the desk in front of me.  It's a local company and I was approached about possibly selling them last year. Bill
Disclosure? I'm looking at a bottle of ice tea that's empty & a clock that says it bed time!
