0 members (), 1,189 guests, and 10 robots.
#194486 06/05/10 01:49 AM
First time using AL cable (#2 feeding a sub-panel), using Ideal brand NOALOX anti-oxidant from a 1/2 oz tube. I had assumed that the NOALOX would be grease-like.
It went on semi-thick (grey in color) then just seemed to evaporate within minutes, only leaving a thin grey residue.
Do this seem correct?
stevepsd #194487 06/05/10 02:08 AM
Semi Thick and gray in color is OK. but evaporate? I haven't seen that happen.
Niko #194489 06/05/10 02:33 AM
It was 105F in the shop when I was doing this....could it be temperature sensitive?
stevepsd #194492 06/05/10 05:27 AM
All a thing like NOALOX is, is zinc suspended in a carrier fluid.
Trumpy #194493 06/05/10 08:32 AM
K
I've noticed that sometimes when I first open a new bottle of Noalox, it seems to be mostly thin, watery liquid on top, like the product has separated after packaging. Maybe that's what's happening with your tube.
I usually just stick a piece of scrap wire down the neck of the container to stir it up but, you may be able to kneed the tube instead.
After this initial mixing and the first use, the inhibitor seems to retain the normal grease like consistency from then on.
stevepsd #194496 06/05/10 11:38 AM
I hope that that feed does not have a 100A breaker on it, as it would be oversized. Did you knead the tube prior to using it to remix it, the product seems to separate in transit,just like real peanut butter does.As was written in KJay's post.
NORCAL #194497 06/05/10 11:42 AM
Hmm ... I've never tried peanut butter. laugh
renosteinke #194501 06/05/10 07:28 PM
Steve, Noalox should be fine, but just a suggestion... try using Penn Unions CU/AL gel. It's non flammable and seems to handle Kern Co temps pretty well... I tried using Noalox in a few pump panels before and it seems to dry out and turn into almost a cement.
Kern Electric on 30th west of Union carries it
Peanut Butter is not listed for the purpose smile
Lostazhell #194502 06/05/10 08:43 PM
My comment was directed at noalox separates like real peanut butter does, was not suggestion to substitute it for noalox.... grin grin grin
Real PB: Containing only peanuts & salt, not homogenized or containing sugar.
NORCAL #194513 06/06/10 04:44 AM
Product may contain wire nuts.
[Ducks and runs for cover!]
