GASparky56
If you would like I could send you pics of how our community does it. Everybody around here has a "low pressure septic" system. There is this box at the side of the house and a tank in the yard. 1HP pump in the bottom of the tank. The box is an ordinary Hoffman swing front, about 18"wide and 24" tall. It's set on galv. strut stuck into the dirt, about 4ft off the ground. PVC Conduit into the tank, (about 20ft away) pvc boxes in the tank and cord grips hanging onto the pump supply and ball switches.
There is a Orange light on the top of the box that blinks if the level gets too high. A sign to call the sewer authority, as they own the whole thing, and it's their problem.
![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
TW
