0 members (), 908 guests, and 9 robots.
#186368 05/08/09 02:07 AM
JoeKP Offline OP
Found this one during the holidays, there was a whole row of these in a parking lot at the insurance company. about five, and a few have 2 romex cables, and like one or two had extension cord/romex in one plug, and was wired into the parking lot lights with a surface mounted transformer to bring the pole light voltage down to 120V. i still wonder how the insides of those cord caps looked cry
[Linked Image from i245.photobucket.com]
-Joe
“then we'll glue em' then screw em'”
-Tom Silva
TOH
JoeKP #186371 05/08/09 09:39 AM
Another fine example of 'temporary wiring'. Did you happen to look at the xfr 'install'?.....just curious.
2-NMC/UF in a cord cap is a good trick!
HotLine1 #186375 05/08/09 12:35 PM
Should be titled WOW! not How.
At least they used UF. I've seen similar with THHN taped together.
leland #186377 05/08/09 05:22 PM
JoeKP Offline OP
no i did not, i was very tempted thought to cut all of those before I left
Lol, i do agree, if i could find the edit button, i would
-Joe
-Tom Silva
TOH
JoeKP #186401 05/11/09 12:15 AM
Just did a re-read....an insurance company??
HotLine1 #186402 05/11/09 07:37 AM
JoeKP Offline OP
HAHA, yeah!!!
-Joe
-Tom Silva
TOH
HotLine1 #186417 05/11/09 09:33 PM
And they're probably "self-insured"...
In Silicon Valley there is/was a UL lab building. Imagine if this sort of handiwork was found in their parking lot... laugh
wa2ise #186429 05/12/09 03:11 PM
I have been involved with Safety and EMI test labs getting product tested for compliance regulations. They usually full of "interesting" wiring practices. 240V 50 Hz bus ducts with 15 & 20 A US recepticles, 240V in 0-280V out Variacs with oversized fuses and electrical tape for fuse covers. 10 KW power supplies with multiple energized output leads just clamped to a piece of wood. Most of the power cord whips I saw had the just the insulated conductors hanging out of the back of the plug. Occasionally I saw the cable just poked thru the knock out with no attempt of strain relief.
These guys made engineers look good.
Larry C
LarryC #189302 09/30/09 09:44 PM
NOT JUST HOW, BUT why????
Sometimes not getting what you want can be an incredible stroke of luck.
gpsparky #189322 10/01/09 02:45 PM
The how doesn't look that hard. Those receptacles use the washer/screw termination. I imagine they just stabbed one wire down each side and tightened the screw. (like a QO breaker)
I bet the handy man was proud of himself and thought it was an elegant solution.
