Electricians revenge
1 members (Scott35), 155 guests, and 14 robots.
Thanks Steve
Z
Reno: Interesting that you mention an OSHA certification needed to perform solar. I was trying to find a cert program for solar when I discovered that the definition for the California C-10 (Electrical) contractor license is defined as such:
C10 - Electrical Contractor
California Code of Regulations
Title 16, Division 8, Article 3. Classifications
An electrical contractor places, installs, erects or connects any electrical wires, fixtures, appliances, apparatus, raceways, conduits, solar photovoltaic cells or any part thereof, which generate, transmit, transform or utilize electrical energy in any form or for any purpose.
Authority cited: Sections 7008 and 7059, Reference: Sections 7058 and 7059 (Business and Professions Code)
http://www.cslb.ca.gov/GeneralInformation/Library/LicensingClassifications/C10ELECTRICAL.ASP
So, solar installation is already covered and legal to perform under a California C-10. As far as data/comm, including phone, data, and cable/SAT pre-wire, it apparently goes without saying, as I've never had my credentials called into question during an inspection by a municipality or any of the utilities related to this work. I've also never failed an inspection related to any of these services.
Zap, the State of California and the Federal Government are 'separate soverigns.' That is, the fact youmay comply with State law has no bearing on whether you also meet federal requirements.
It's the same situation with asbestos and refirgerant licensing. The difference is that the refrigerant license is good for a lifetime, while these others need to be renewed annually.
