0 members (), 174 guests, and 10 robots.
If it continues to operate then you have corrected the problem. If it happens again, take it to a motor repair shop. If it is the centrifugal switch you can't fix it yourself.
You did not mention what size motor it is. If it's small, a new motor may be cheaper than a motor shop. If it's a special motor (non-Nema) then you need the motor shop or manufacturer.
Originally Posted by Wolfgang
Electrolytic equals DC device.
Typical motor capacitors are MetalPaper or alike and lose permanently a little bit of their capacitance. But usually isolation remains constant because of a "self-healing"(direct German English translation) mechanism until end of life.
Electrolytic were actually invented for use as a motor starting cap, and most work just fine at 60Hz.
Steve,
as far as I could "google" on that issue you're right for the 19th century. But I have never seen an electrolytic capacitor on an AC motor in my last 52 years, at least on this side of the pond.
POLARIZED Electrolytic Caps equal DC usage.
NON-POLARIZED Electrolytic Caps may be used on AC Circuits.
Start & Run Caps were typically Non-Polarized Electrolytics, as were Power Factor Correction Caps.
Now I believe there are options for "OK Caps" (Non-Polarized Electrolytics), and "Better Caps" (Polypropylene, etc.).
The last Start Capacitor I replaced - apx. 1998, was a Non-Polarized Electrolytic (the replacement item).
HID Ballast Caps were mostly all "Wet" Non-Polarized Electrolytics (pre-year 2000), but now they almost universally use "Dry Film" Caps, which I would imagine are something in the Mylar realm.
"Cheap-O" Crossover Caps are Non-Polarized Electrolytics.
Better quality X-Over Caps are Non_Polarized Polypropylene, and Mylar.
Scott
Okay, it looks like that there really is a significant difference in use, probably not due to different frequency but to single phase voltage of 230V.
I have learned something new to me.
A non-polarized cap is usually 2 polarized caps back to back.
