0 members (), 1,316 guests, and 21 robots.
wa2ise #184004 01/30/09 03:16 AM
Wouldn't a decorative tile cover been easier?
wa2ise #184012 01/30/09 11:15 AM
OK, how about using one of the high end, color devices that 'match' the green tiles?
wa2ise #184023 01/30/09 06:13 PM
Its wonderful example of craftsmanship, its not often you see a hack done so beautifully.
I think flat decora switches & recepts would've looked cleaner than the toggles laugh laugh
PS these devices look new, is there a GFI in the mix someplace?
And agree'd, premium craftsmanship, just that darn accessibility code thingy...
wa2ise #184311 02/06/09 10:23 PM
K
It's hard enough to get someone to cut that neatly around boxes.
wa2ise #187168 06/16/09 02:36 AM
its hammer time lol smile
Luke McCoy The NEC Crazy Boy
wa2ise #190568 11/24/09 07:03 PM
Luc Offline
Wow, it would look better with GFCI/Decora devices Haha. But seriously, it must be impossible to access those boxes.
wa2ise #190593 11/25/09 06:29 PM
You've got to appreciate the workmanship.
pdh Offline
Would be nice if some plate manufacturer would make custom sizes (larger than the minimum covering needed) and custom colors (send in a color sample to match). With some alignment work (devices centered in the tile positions) you could have plates that match the tiles, but meet the requirement for being removable to access the devices. Having the plates listed might be harder to do.
pdh #190614 11/27/09 03:11 AM
Many wallplates are available in midway and oversize sizes. As far as custom colors go, that would be insanely expensive in a molded wallplate, and merely prohibitively expensive in a painted metal plate. frown
