0 members (), 1,017 guests, and 10 robots.
#180151 08/14/08 10:39 PM
This gem had UF in it, I love it!
- HCE727
[Linked Image from electrical-photos.com]
Admin #180156 08/15/08 03:10 AM
The amount of work someone will go through to do something the wrong way never ceases to amase me.
~Matt
I would rather beg for forgiveness then beg for permission.
TOOL_5150 #180208 08/17/08 10:54 AM
We have a 200a service on a milk container company(DIY job)that use 2" pipe with the same setup. I look at it and wonder how the even got the wires in it. Probably pussed them in as the went along.
Ob
Obsaleet #180271 08/20/08 10:31 AM
At least it's protected from physical damage to the extreme
Ann Brush #180326 08/21/08 08:57 PM
Unless they killed it when the pushed/pulled/threaded it in!
Must have been one of those plumtricians, or elecumbers.
HotLine1 #180328 08/21/08 09:27 PM
twh Offline
Although those are probably plumbing fittings, they look like electrical ELF fittings.
twh #180534 08/29/08 06:56 AM
UF is considered its own raceway, isn't it? AFAIK, there's no restriction in what you can do to cover a raceway, so long as the pull boxes, etc, are exposed. Wouldn't this be acceptable, if perhaps not the easiest way to get it done?
SteveFehr #180544 08/29/08 12:12 PM
The fittings in the pic appear to be plumbing items, as are the nipples. Therefore, unlisted items are being used for an electrical install.
No sense beating a dead horse; non-compliant installation.
HotLine1 #180706 09/06/08 08:41 PM
I agree with HotLine1 that looks like galvanized pipe fittings.
I have a sense of adventure, I just keep it leashed with common sense.
