Electricians revenge
1 members (Scott35), 128 guests, and 12 robots.
tomselectrc #175108 02/22/08 08:09 PM
---the fan is on it's own curcit,it is in the stairway that is in the bedroom.--
There you are. 120V, 2005, AFCI.
---i'm going to see if i can move the switch on the stairway landing hopefully he will except that instead of changeing the motor ---
The switch is not an outlet. The fan is.
Just disconnect the fan motor. If the breaker holds, it's not the ckt,it's the fan.
good luck, keep us posted.
leland #175132 02/23/08 02:20 AM
Actually it is not that easy Leland. If the neutral is shorted to ground it won't trip the GF portion of the AFCI until you put a load on it.
gfretwell #175133 02/23/08 05:48 AM
Thats correct Greg, I did over look the obvious.
In the end, Most likely the 30yr old fan. A new fan would be more economical as well.
leland #175153 02/23/08 01:23 PM
On the other hand a 30 year old fan probably has oil cups in the motor and properly maintained it may last another 30 years. I have two at my house like that and I can't bring myself to replace them with some offshore "throwaway" unit. They are quiet and move a lot of air. I guess I should put the clamp on one and see how bad it really is.
tomselectrc #175431 02/29/08 09:19 PM
The code is pretty clear ... every "outlet" ... and a switch is not an outlet.
