I don't see how pulling #12 could cause problems; you could pull #10 home runs if you wanted to, they're both rated for the maximum allowable circuit current that the breaker is supposed to allow. However, If you were pulling the same size conductors on a 20A protected circuit, I would be concerned about the #14's.
What problems do you see arising from your situation?
Shawn.
