0 members (), 473 guests, and 14 robots.
Paul, what is 'V' in the meter?
Workgear for Electricians
Looks to me like V is potential and I is current
Paul: thanks for the diagram. This is making a lot more sense now. smile
Paul: in your diagram it shows the main switch opening the hot and neutural conductors, is this correct? We never open the neutural or EG conductors here.
Jimmy
Yes, they're just the voltage and current coils in the meter.
Yes, that's one of the many little differences between American and British practice. The main switch on a single-phase service here always opens the neutral.
Just to make things interesting, however, on a 3-phase service the main is usually just triple pole and does not break the neutral!
But double-pole isolation on single-phase circuits is used extensively here: The local isolation switches for an electric range, fixed water or room heater, etc. are normally all double-pole, breaking both hot & neutral.
