0 members (), 2,142 guests, and 49 robots.
walrus #167217 08/08/07 10:53 AM
Originally Posted by walrus
Is there anyway to make the reply box bigger??
Click on the [Linked Image] symbol above the box a few times and it will expand. It only works for individual replies though.
There doesn't seem to be a way to set a larger reply box by default in personal preferences. I too find the default size much too small to see what I'm doing, especially when cutting and pasting sections, entering image links, etc.
Workgear for Electricians
pauluk #167220 08/08/07 11:51 AM
I found a setting to change the default size of the reply window. The question is how big to make it ....
The way it appears is going to look different depending on screen resolution being used.
I changed the settings to make it twice the size vertically and 1/3 wider. Any comments recommendations? Please include the resolution you are using.
Admin #167225 08/08/07 12:43 PM
Looking good Bill.
I'm using 800x600, 1024x768, and 1280x1024.
Ian A.
