0 members (), 471 guests, and 23 robots.
Scott35 Offline OP
Topic: Some pictures of RW and TW Conductors
Here are a few images of # 8 Solid Copper Conductors with RW and TW type Insulation.
Image #1: Overview of both types of Conductors - the "RW" has Black Insulation, and the "TW" has White Insulation.
Image #2: #8 Solid Copper with RW Insulation.
Image #3: #8 Solid Copper with RW Insulation - close up.
Notice the Tinned Copper.
Image #4: #8 Solid Copper with TW Insulation (White).
Image #5: Close-up of #8 Solid Copper with TW Insulation (White).
Note the printed text.
Imaging pulling Three of these bad boys through a long run!
Somewhere in my "Archives" I have some Solid #6 and #4 Insulated Copper Conductors - imagine pulling those puppies!!!
eek
Scott
Latest Labor & Material Cost Estimating Guides
Latest Labor and Material Cost Estimating Guides
I'm fairly certain that tinning of conductors keeps copper and rubber from chemically reacting, preventing corrosion of the copper conductor.
Scott35 Offline OP
Scott - how have you been!!! smile
It sure has been a long time since I saw a posted message with "Bjarney" attached!
Hope everything is going OK in the "West Southern Inner Northeast ... "
Just an FYI, my E-mail address has changed (again), and is no longer within the "Pacbell" domain.
Here is a Phonetic version of one address, which messages will actually be accepted by the Mailbot, and not bounced back with SMTP Error 550:
designer at setelectric dot net
(remove the spaces between words, swap the word "at" with the "At" symbol [Shift + "2"], and make the "Dot" a _Dot_)
Send me a message when you get an urge to speak geek!
Scott
