0 members (), 317 guests, and 39 robots.
Originally Posted by renosteinke
I suspect that, like LED's, the dim-able CFL exists only in the marketing departments.
Dimmable LED's do exist, have installed them several times. CFL's I have not found to be dimmable yet.
JJM Offline
The biggest thing that annoys me about CF bulbs is they're somewhat dim when starting up. It takes them a few moments to get up to full brightness, so when you first walk into a room, it will be a little bit on the dark side for a short while. I also don't like the bit of "flicker" they make on start-up.
Once they're warmed up however, they're fine, almost no difference between them and incandescent lighting. In fact, they make great replacements in those NuTone and Broan range hoods fans, where incandescent bulbs almost immediately discolor the lens... or any application where plastic lenses become discolored by heat from incandescent bulbs. My basement kitchen has one of those "low-end" hoods that always had the filter lens getting an ugly brown spot from the heat of the bulb. Lower wattage and different sized incandescents didn't help. Put a CF in there and the filter lens assembly stays like new... and the wife is happy!
They're also ideal for applications where "over-lamping" would violate a luminaries rating (as I learned is okay here). You can really push out a lot light from luminaries that are inadequate with a "higher output" CF that's within the luminaires wattage rating.
Given my obvious disdain for all things "green" I bet many of are surprised to hear me - of all people - extolling the virtues of CF bulbs. But I have to be honest, and therefore, I can find little fault with these bulbs themselves. What bothers me is the idea that using them will somehow have an effect on climate. That's ridiculous.
Perhaps the biggest downsides with the bulbs are those who use PLC type lighting and home automation systems, like X10 or Insteon. Those devices usually tend not to get along very well with CF bulbs. If you're lucky (or unlucky) enough to have Lutron, it's usually not a problem.
I agree with Reno though on quality control of those bulbs... either they last forever or fail right away. Thought it was just me! But that's another benefit of these bulbs, you don't need to change bulbs often. Less trips up the ladder is a good thing!
Joe
I do quite a bit of restoration work (my specialty is the reproduction of antique light fixtures) and have found CFL's to be abn excellent replacement for incandescents in many antique designs, as long as the fixture has an opal shade or diffuser. The many "Scientific" fixtures (usually intended for commercial, industrial, or institutional installations) produced in the two decades after the introduction of the Mazda C lamp (Gas-filled, coiled coil tungsten filament, 100-300 watt) among which are the so-called "Schoolhouse" fixture, and most of the semi-indirect units of the 1920's, offer excellent light distribution and quality. They were replaced in general useage because of the superior efficiency of fluorescent fixtures. Modern CFL lamps work extremely well in these fixtures if the installer takes care to position the socket so that the center of illumination of the CFL is located in approximately the same position as the center of illumination of the incandescent lamp for which the fixture was intended. One must always remember that the high wattage incandescents of the 1920's and 1930's were considerably larger than those of the modern era, and that the efficiency of vintage fixtures suffers terribly when modern replacements are used without the proper adjustments. WHen used porperly, however, the CHL can give these eighty year old fixtures a new lease on life.
Baby steps in the right direction, rather than trying to move heaven and hell. Although, some make small changes seem that way...
ge makes a dimming cf
Good idea with the dates winnie. I have done that over the last 10 years on my normal filament lamps and the CFL lamps.
Haven't had any faillures yet, some of my lamps have hour meters on them and have done between 206 and 13499 hrs. (highest reading).
Ok the ones we use are the 230 V 50 Hz ones. most are Philips brand.
[quote=JJM]Perhaps the biggest downsides with the bulbs are those who use PLC type lighting and home automation systems, like X10 or Insteon. Those devices usually tend not to get along very well with CF bulbs. /quote]
Joe: Would you please expand on "not to get along very well"? I have a houseful of X10 controls, but thus far only one floor lamp with CFL's on an X10 appliance (non-dimming) module. It repeatedly turns itself on. I have gotten in the habit of switching off the units by hand at night, which kind of defeats the purpose of having X10. frown
I haven't gotten into Insteon yet. crazy
JJM Offline
There are a few likely scenarios...
One scenario could be the "local sense" control on the X10 appliance module is charging up the CF ballast, resulting in discharge noise of sufficient mV around the 120 KHz band to trigger the lamp back on. Assuming this is the problem (does it occur when a regular incandescent bulb is used?) there is a simple way to modify the module to disable local sense control. There are also appliance modules available that give you the option of disabling local control, which is preferable when CF bulbs are controlled.
The other scenario could simply be excessive line noise from some CF bulbs. I've seen some CF bulbs generate over 600mV pulses on my X10 signal analyzer, as well on the scope. You see their "clipping" noise dropping well into the 120 KHz range near zero on a 60 Hz waveform. They also extend enough into the 131.65 KHz Insteon range, wreaking havoc on there too. In this case, filters are needed or "better" CF bulbs.
Let's face it, when X10 was invented in the mid 1970s, there was no such thing as CF bulbs, so we have to adapt to mixing new technology with old and deal with the resultant issues... sometimes by trial and error.
Or you could simply be experiencing typical X10 problems, which have nothing to do with the CF bulbs at all. A whole house blocking coupler over the netural in the panel, and a whole house phase coupler amplifier repeater are "standard issue" items for reliable X10 control... yes X10 can be made to be VERY reliable.
Joe
P.S. Sorry to hijack this thread somewhat. I'd understand if the moderators saw fit to move it under a separate X10 topic.
I don't have this problem with incandescents in floor lamps, though I have a wall switch in the bathroom that gets notional now and then.
Thanks, Joe! Good info! smile
My outdoor landscape floods have all been replaced with CF's. I have no problem with the X-10 controlling all four circuits.
pcsailor
pcsailor
Minneapolis, MN, USA
Trumpy 5
davey 1
551,659 Are you busy
426,207 Re: Forum
396,888 Need opinion
