0 members (), 458 guests, and 24 robots.
F
I just purchased a nice little Sperry DSA-500 multimeter at Home Depot for $49.00. It seems to work just fine. However, it is not a true rms multimeter. Will it still measure voltage accurately?
Depends on what sort of accuracy you require.
Any non-TrueRMS meter will test the Average voltage (as in 63.7% of the peak voltage) as opposed to 70.7% (RMS).
F
I just need it to test voltage drop at the outlet, neutral-ground voltage etc.
By rights, there should be no voltage between these conductors.
I could be wrong too.
Frank,
A T-RMS meter is only of value to those that measure voltages with lots of harmonics on the supply.
The average electrician doesn't need to worry , I have one, but I wouldn't recommend every guy runs out and gets one.
My Fluke 80 does just as gooder job and why spend good cash when you don't have to?.
Lostazhell
Lostazhell
555,808 Are you busy
430,644 Re: Forum
400,006 Need opinion
