Electricians revenge
0 members (), 192 guests, and 14 robots.
Charlie, Is it possible that you have an unbalanced system and the buss / terminals in question are getting hot? That would cause any condensate to evaporate, leaving behind mineral deposits.
Try this to get to the article--
Go to http://ecmweb.com/
Pick "Browse Back Issues"
Pick "Dec 2000"
Scroll to "Maintenance Facts"
white powder corrosion is an aluminium thing.check that the lugs used are compliant with the bus bar. id also clean everything up with a wire brush and make sure all the connections are tight. you say that the area isnt damp, but how far away from the sea are you. seaside areas suffer a lot from the salt in the air.
