by Hutch - 05/12/24 10:45 AM
Electricians revenge
1 members (Scott35), 165 guests, and 11 robots.
#159464 01/27/07 11:05 AM
ito - it is keeping it simple.
you run an 80 man union shop, and cringe at the thought of those 80 men pricing a job. correct?
imagine running a 20 man residential shop where the guys do price the jobs. jobs that are $500 to $5000 dollars.
do you want them to walk in look at a job, then figure out how long it will take, figure out all the material needed, figure out the OH & Profit, add it all up and give a price?
or would it be easier to look in the book that has the average prices for that job, and just adjust it accordingly?
takes much of the risk out and keeps it simpler.
Latest Estimating Cost Guides & Software:
#159465 01/27/07 11:25 AM
Jps1006 Offline OP
Just to clarify, I'm not looking to start the "to flat rate, not to flat rate" discussion here. There are many good reasons to do it for particular business plans. I see the wisdom in it from first hand experience. If any of you want to rehash those views, please start a different thread. I promise I'll contribute.
Also, I'm not asking how to figure up a price on the example above.... I'm asking more specifically how to do it using a flat rate book. I'm interested in the day to day technique and the different variations people have to them. It's more about using the book than figuring the job.
[This message has been edited by Jps1006 (edited 01-27-2007).]
#159466 01/27/07 11:37 AM
jps,
flat rate is a guide. you have to educate your guys how to use it. but what it does is keep them in the right ballpark so the customer gets the correct job and the company makes the money it needs.
as for your question, everything is a task and everything is an adder. huh?
customer wants you to put in the 240v and the 120v line. both jobs have a price for primary task and additional task.
our pricing would be the following:
primary task - install 240v line in emt (this would include the circuit, a standard breaker, receptacle and all misc parts)
additional tasks:
adder for FPE breaker
adder for 120V circuit (includes outlet and breaker)
adder for dryer plug
(all these prices are in the price book as adders)
pretty simple and basic.
now, if you had to drill through a concrete wall, or if it was a QO panel and you needed to install a twin breaker to make some room, or anything else, they would be adders.
now the customer would see the following:
install 30A 240V circuit from existing FPE panel to location of dryer. Install 30A 250V dryer receptacle. Install 30A 250V cord set on dryer - $x.xx
install 20A 120V circuit from existing FPE panel to washer machine location. Install receptacle for washer machine - $x.xx
Simple as that. But those prices are based on all the job conditions. The only difference between this and what ITO proposes is that with this information in a price book, your technician can look everything up and adjust according to the field conditions. He doesn't have to start from scratch.
ITO's idea is fine if you have only a couple of people who price everything out.
Oh, the primary task includes your travel and setup time.
[This message has been edited by mahlere (edited 01-27-2007).]
#159467 01/27/07 03:10 PM
LK Offline
"Simple as that. But those prices are based on all the job conditions. The only difference between this and what ITO proposes is that with this information in a price book, your technician can look everything up and adjust according to the field conditions. He doesn't have to start from scratch."
And that is what helps us, having the information to put it all together.
Please don't confuse a pricing guide with a pricing book, the guide system is more of an on the site estimate, where the pricing book may be used by volume service providers, in and out pricing, IMO not a good business practice.
#159468 01/27/07 03:18 PM
Jps1006 Offline OP
Very helpful, thanks guys.
mahlere,
for distance on the 240 & 120-volt runs, do you use a multiplier or do you have different length line items like A-line?
#159469 01/27/07 07:04 PM
Did you buy or make that book?
I bought software that had inventory and tasks already set up in it. I made a lot of modifications to the tasks and inventory. With the software you print out your books.
Do you have a way to account for fluctuating material prices (i.e. automatically tie into purchasing etc.)?
I update my material prices manually. The software allows you to download material price updates into it but I haven't done that.
What if I decide I can put (3) #10 & (2) #12 in a 1/2” EMT?
How do you account for the drastic price difference between a GE 2-pole 30 and a Stab Lock?
I have add-on tasks for this. For example if I want to add wire to a conduit I use an add wire in conduit per foot task. For a federal pacific breaker I would use an add-on task for installing it. If I need to install a device that costs more than a dryer receptacle I would use an add-on task for that.
I usually put a work description right above the list of tasks.
Example:
Install 30a circuit for dryer & 20a circuit for washer. Install dryer cord.
JBF-1060-0060 Daily Job Fee (For Job Setup, Cleanup & Paperwork)
DCL-3050-0240 Dedicated Circuit: EMT Conduit 30a Limited Access
DCL-1001-0000 Add Additional #12 THHN Wire In Conduit Per Foot
BFP-2051-0005 ADD-ON Install Federal Pacific 30a Double Pole Breaker
BFP-1016-0005 ADD-ON Install Federal Pacific 20a Single Pole Breaker
AHU-1006-0030 Install Dryer Cord 30a
These tasks have different price columns so I can make adjustments if I feel the job conditions will make the job easier or more difficult. I could also go from a 50ft. run price to a 75ft. run price if I felt the 50ft. price was to low.
If I need to setup scaffolding or something I have tasks for that as well.
Keep in mind I'm new at this and I'm not saying this is the best way of doing this. This is just how I'm currently doing things at the moment. I'm very interested in learning how others do this as well.
[This message has been edited by A-Line (edited 01-27-2007).]
#159470 01/27/07 07:39 PM
LK Offline
Also the software allows you to do T&M Billing, and as A-Line said you can build your own custom sheets.
I had actuals for the past 45 years, a lot of the builds were in spring binders and some in files, i transfered a lot of that to excell, then found it was a lot of work to move it around, so that is when i bought the service software, i felt the $145 was cheap and the support has been better then expected.
#159471 01/27/07 10:18 PM
jps,
are runs are up to 25', after that there is a per foot price for each wiring method.
#159472 01/27/07 10:32 PM
ITO Offline
The problem I have had in the past is every time I teach someone how to estimate or price jobs; shortly thereafter they start looking at me as the middleman between them and their money. Another problem I used to run into is they start adding up all their tickets figuring all the profit, then use this information to ask for a raise, at new truck or in a worst case scenario to justify dishonesty on their part.
So every time I hear about a “technicians” (is that what yall call electricians up north?) pricing work, I just cringe. Here is some advice take it or leave it I don’t really care, but if you have enough men running around and doing work, and you think you need a pricing book, take a step back and consider hiring a salesman/estimator. It’s never a good idea to mix the business end with your labor; the very most a serviceman should be doing with paper work is write up the hours worked and the materials used. If you cant support a salesman/estimator then you need to be doing it yourself sspecially if its only a part time job right now.
Again this is just how it works for me, some other business model may work you and that is fine but keep this in mind, 3 of my biggest competitors all started at my shop.
[This message has been edited by ITO (edited 01-27-2007).]
101° Rx = + /_\
#159473 01/27/07 10:54 PM
ito,
i feel you. but there are some very vocal opponents to us making money. some of them are right in our own industry.
now for residential service calls, where our job average is about $400/ticket. I couldn't justify having a salesperson/estimator look at every job. it would bring that ticket avg to $500. Thereby costing the customer more money.
if we did this work at T&M, our avg ticket would be about $300, but that would leave us pretty much bankrupt.
my guys can add up all they want, but they also know what most of the costs are. They know what the advertising is, what the trucks cost, etc.
I look at it this way, if they are gonna go on their own, they are gonna go on their own. nothing i can do to stop them. keeping them in the dark won't stop them. it'll only make them ignorant competitors when they do.
if they know the deal, they won't start out trying to work for $50/hr and wonder why they can't seem to make any money.
but that's just what works for me. but, we've been a union shop before, and it's a different world. most of those guys are not going out on their own, except to moonlight.
big difference.
